242 SE bilge pump runs 3-4 times on a regular outing
Salt Air
Tarpon Springs Fl
Does anyone else notice their bilge pump running for 30 seconds or more 3-4 times a day during a normal use day? Is there a chronic problem with the drain plug. I replaced it once and check for shavings in the bilge.
adrianp89
Tampa Bay, FL
252SE
Has your anchor lock drain been repaired?
Salt Air
Tarpon Springs Fl
Has not, never had an issue there.
adrianp89
Tampa Bay, FL
252SE
I would check it to make sure it is sealed completely from the inside to out. Pretty common issue.
