252 SD RPM wind up
nosterka
252SD
Hey guys, was out last week and had my 252 sd wide open and topped out at 7k on the port engine and about 6700 on the starboard engine. First is this normal to have a difference? I did have the throttles synced. Second I notice boat test mag topped out at 7400 and 43 mph, I was at 40 mph. So should I be revving up to 7400 wide open?
Thanks for the help
lowd77
Minnesota
252SD
Something doesn't sound right. I get 7600 rpm and hit 46 mph in Minnesota.
nosterka
252SD
Thanks for the response, I didn’t think so. I’m going to call the dealer in the morning and talk to them. While on the water I thought it should wind up higher but wasn’t sure so sounds like something might be up. Other than that it seems to run well.
HangOutdoors
Royal Oak, MI
Thanks for the help
Did you check the oil? Maybe dealer over filled it. Our engines are very sensitive to oil level and in can decrease performance and RPM's significantly. Also check your air filters. Oil should be below have, for optimum performance. If you are full up it can and will knock off some decent RPM's. And if it is, I would be wary of the dealer whom did it. Additionally, your spark plugs may have some issues with gap, etc. Mine from the factory were off and when I corrected them I picked up a couple hundred RPM's
Also you will always have different RPM's on your engines at full out, mine are 250-300 different.
nosterka
252SD
I did not check the oil but will look at that. This might be a dumb question but going to ask anyways....while on the trailer as long as it’s level should that be good to get an accurate reading? Do you happen to remember what the gap tolerance should be on the plugs? I’m guessing it’s about 250-300 rpm difference at wot so that’s good to know it’s normal. Thank you for the help so I can see where to start. My local dealer is about 1.5 hrs away and then 5-6 hours for the next so I’m hoping the closer one is decent. Thank you again.
Sean R
Acworth GA
212S
Mine are also, port 7600 stbd 7300. that is normal? I was going to swap impellers to see if lower rpms switched engs. I'll also check oil and airfilter.
HangOutdoors
Royal Oak, MI
My engine's run at 7700 and 7500/7400 WOT. Yes your engines will run add different RPM's wide open throttle. That is working as intended. There is a thread around here discussing that and why, I just can't seem to find it at the moment.
Yes check oil level. Midway between L and Half way. Under a half. If you are full or overfilled, you may have saturated your air filter. You can always pull your air filters and make a run with and without them to see if there is a difference.
Sean R
Acworth GA
212S
I am pretty sure my oil level is good, I do the mantaince. I put in the same amount I pull out, but worth checking, again. Shit I check the oil almost every outing.I haven't checked the airfilter since February, also worth a check.
HangOutdoors
Royal Oak, MI
just throwing some things around, hoping it is an easy resolution.
Sean R
Acworth GA
212S
Not to change the subject BUT I just got the Ark 750 trailor jack cant wait to install. Your previous threads talked me into it 😎
nosterka
252SD
Just wanted to add the boat only has 7hrs on it and this was the first time I really went wot, was not comfortable with prior conditions to attempt. If the boat had too little or too much oil that wound be from the factory and something missed on the PDI, correct? I plan to call and talk to the dealer as I was going to have them perform the 10hr service, would do it myself but I’m not sure I would have the time right now.
nosterka
252SD
Dealer said they would check it out but said it could possibly be elevation causing the low RPM as we are at around 4,000 feet. Could this be a possibility?
Sean R
Acworth GA
212S
It could, there are a few threads on here regarding poor performance at high elivation and the modes to improve.
