252SD hull drain plug
nosterka
252SD
Apologies if this has been discussed but I couldn’t find any other topics, but will this fit my 252SD? I would like to carry an extra hull plug just in case and this is all I have found so far. I asked my dealer but they are sold out and said it’s been hard to get. Thanks in advance.
1WetBoat
Tampa
That is the one I also ordered as a backup. The existing drain plug on the 25' boats have little "wings" on the end which is what keeps them attached when you unscrew them.
To use this as a backup, you will have to pull out the original one(Unless you lose it) bending the little wings, then unscrew this one from its base and screw it into the one on your boat.
nosterka
252SD
Yeah I am just looking to keep an extra if mine gets damaged or something random causes it to not be usable.
