ChrisM
- Rock HIll, SC 29730
- Chaparral
- VR
I do not ski, and I don't know anyone that does, so no tower for me. I am properly equipped with a tow-able hook center transom below the hand rail. From what I gathered when I originally built mine was the VRX was already the ski inspired version, IE: already equipped with the tower. The Chaparral brand is a "made to order" and not a "Production"boat, say like Tahoe. I looked at a couple brands before my Vortex purchase, and found while not feature rich like some of the others, IE: live well, sink, fridge, trash can, whatever, the use of space and quality is really obvious. Things like clean-out plugs are not important to me, I've never had a need for them. The only time I was down I was riding my SeaDoo (same engine and propulsion) I sucked in a thumbnail sliver of cedar wood. I lost power, heavily cavitated, and had to be towed back to the launch. What I found was this tiny piece of wood had been depressed into the wear ring. The only fix for this was to pull the pump to remove which is really easy. This is something that can happen to ANY jet drive system due to the tight tolerances between the impeller and plastic wear ring, Install a stainless, or metal wear ring as an alternative and you'll be putting more of the wear on your impeller.
