Khalid
- 255XE
So, this is the 2nd season on my 255XE. Last season I put over 100 hours on it and it did great (I posted couple of the issues that needed to be addressed off season in a previous post)
This season, I purchased 800 lb fatsac made for Yamaha to set on the back seat / platform. Needless to say, since the back seats are now higher than the previous models, the fatsac wouldn’t fit (they’d slip off with movement). So, I purchased 2 workout steps from Amazon and stacked them on top of one other on the back platform (10” total) and placed the 800 lb fatsac on it. That worked very well to secure the sac.
I continued to fiddle around with the play factory ballast. I found that in addition to 800 lbs sac, I need 100% of port side and 55% middle and 0 on starboard to work the best.
Now, one thing that surprised me is that in order to get a true to 10-11 MPH actual speed, I’ll have to set target speed to 13.5-14 MPH. However, the boat still shows actual speed at 10 MPH (even when set to higher speeds). It seems like the actual speed is not correct.
after all this, I’m able to generate a very surfable wake that Is high with deeper pocket than before. I think there’s still roomfor adjustments to make the pocket even bigger by partially filling the starboard ballast.
p.s rope isn’t an indication with the wale performance but the rider’s novelty
