Troy JK
- 242X E-Series
I Stopped off at a boat dealership to pick up some 5200 for my tab install. The counter guy asked what I was using it for so I told him. He said he didn’t think it was a good idea. About that time a mechanic walked up and he asked his opinion. The mechanic said “ you can use it for that but I wouldn’t, if you ever bend one and have to replace it, there’s a good chance you’ll take some gelcoat off with it, the 4200 would be better. I thought about it for a second and went with the 4200. My thinking is that with our application, the actuators are pushing the tabs against the hull and not away from it so the extra bond strength isn’t needed.
I also did a quick net search on it and found one post from a guy that said he had removed an outboard that had 5200 just around the bolt holes. he lifted the boat off of the trailer trying to get the motor off after the bolts were out. When it did come off it took some gelcoat with it.
I’m not going to say you can’t get them off with a little heat and the right razor blades, but in our application I don’t think it’s worth the risk.
This may have been debated but the closest I found was in 2014.
