Liberty195
- Scarab
- 195 Open ID
My 2017 Scarab with the 4 tec 250 came with green coolant in it. I believe it’s original but I don’t know for sure, just bought it last fall. Decided to change the coolant and lots of folks online like the peak orange dex/cool for extended life in rotax so I used the process in the manual to drain the green and re fill with orange dex cool. Watched all the green pee out and turn solid orange with my helpers filling and then put the drain screw in. Then a hour later I started googling to see what my coolant capacity is because I was thinking i need another gallon for top offf and read how you should not switch from green or orange line I did. Darn it!
Soooo 90 min after finishing filling with orange, I drained the orange and then poured 3 gallons of filtered water through to be sure I got all of the orange out. Have nice clear pee now. Can’t imagine gelling in 90 min. Engine has not been ran.
I’m thinking I should just put green back in, correct? Engine never ran so the green still in the block didn’t mix with the orange. Best to use like a zerex all purpose green and call it a day?
