4-TEC Reverse Bucket Adjustment
thirdjet
sturgeon bay wi
Glastron
GT
The reverse bucket on my Glastron 187 GTS will not lock in the forward position and seems to be partially in the jetstream. To adjust it, I have disconnected the cable from the bucket, removed the cotter pin and plastic cover on what I think is the adjustment mechanism and tried to turn the threaded fitting, which I think would adjust the cable length. I cannot get the threaded tube/fitting to turn as space is very tight. Is there a special tool for this? Or am I doing something wrong? Is there any other way to adjust this? Any suggestions? thanks.
I had a similar issue. The 1st time I adjusted it I took off the entire reverse bucket to inspect the wear ring at the same time.
Without removing the bucket you have to push the cable up about 2 inches to give it clearance to spin freely. It’s a little tight in there but it will spin.
