BradGoins
- High Point, NC
- X
Hey guys,
The last owner had installed an amp behind the instrument gauges and I believe the amp doesn't work any longer. May question is what is the best way to get into this area to remove the amp?
I see the screws on the gray instrument gauge panel (depth finder, both rpms, speedometer, and gas gauge), is the best bet to remove these screw and access this area from the top instrument gauge area? If so, what should I look out for when accessing from this area.
The amp is mounted directly above the steering column so access from below is going to be tough.
Also if you guys recommend another location for the new amp which can be access easier I'm all ears.
