Accessories not working following battery swap
Frog156
i replaced my battery recently and non of my accessories will work. I heckled the fuse coming off the battery and it was good. Any ideas?
Does the boat start? The accessories line are hooked up to positive and negative terminals respectively? Did you miss a connection. I know mine will fall behind battery when unhooked.
you should have at least 3 cables hooked up to each battery terminal,
