Englewoodcowboy
- Ceres, VA
- X
I am going to chronicle my ballast mod and upgrade on my new 212X. What my current plan is to modify the existing set up and go from there. For example, making it selectable to fill one bag for surf or both for wake. The first piece of my puzzle was the design and analyzing of what the boat came with and how my plans are to use it. Since I do not want to add another pump at this time, I am adding an electric ball valve to the starboard tank since I am only setting my boat up to surf on the port side (normal) with a single wedge. Since our system comes with a built in timer I wanted to make sure I do not have to fool with it (though I am increasing the fill time for more ballast for wake boarding. So to combat the excessive fill time when filling only one bag it needs to be vented and after doing some research I have found a successful way to cut a vent into the bags. Worse case scenario if I decide to get a custom bag made for the port side it will just be a matter of switching the fittings, all of the plumbing will be in place.
As an important note, it is very important for me to make this look like it came form the factory that way, don't ask me why, just a pet peeve of mine on things like this. So hopefully the execution meets my desired results.
So far parts list and cost:
1 DPST (on-on) custom rocker switch - $18.00 - OTRATTW
1 SS 3/4" 12vdc Full Flow Ball Valve - $30.00 - AMAZON
15' of marine grade 16awg 3 conductor wire - $20.00 - WEST MARINE
1 - 3/4" chrome plated through hull fitting - $7.00 - AMAZON
1 - 3/4" 90° through hull fitting - $6.00 - AMAZON
4' - 3/4" pvc hose - LOWES
2 - 3/4" SS Hose Clamps - $20.00 - AMAZON
2 - 3/4" ID x 1.5" OD x 1/16" silicone seal washers - $10.00 - McMASTER
Here is a teaser of one of the first parts that arrived so you can get a feel of where I am going with this:
