Also looking for manual
MRicci
Wasaga Beach Ontario Canada
Sugar Sand
Mirage
Hi just joined this site, I bought a 2008 Sugar Sand Mirage last fall, have had it out a few times & loving it, but also like a few other people here, I am unable to find an owners manual. Any help would be greatly appreciated. Also I am from Wasaga Beach, which is about an hour north of Toronto, so hopefully I will also be able to find parts if and when needed.
Glad to have you on board,
unfortunately not a lot of info on these older boats, be sure to read through the sugar sands forum,
if you're having a particular issue post the type of engine you have and the problem and we have some formers owners that may be able to give you advice,
hello. I just bought a 2007 AR210. Any chance of anyone having a printable PDF boat manual? The boat didn’t come with one and of course all available now is non printable e-manual. Thx.
Check here YAMAHA BOATS OWNER'S MANUALS These are not PDFs but you can read them. With a bit of work, you can download each image and make a PDF ?
Thx. I have the emanual ready to browse thru. Really didn’t want to have to print all 130 some pages one at a time. Guess with this covid-19 happening, all I have is time on my hands. Lol.
cheers.
cheers.
I work with computers for a living and this is what I did when I wanted to get a PDF of my manual. It's not the most straight forward thing but it works. If you are comfortable with a computer command line then it should be easy.
Code:
1) Go to https://boats.yamaha-owners-manuals.com
2) Fill out your Year and Model to access your manual.
3) In your browser, you'll see an URL that looks something like this:
    https://boats.yamaha-owners-manuals.com/om/LIT-18626-07-19/LIT-18626-07-19.html
4) Remove the last part of the URL to make it look like this and keep a copy of it. You'll use this in step 6.
5) At the command line (Linux or MacOS. Windows... not sure about!) setup a new directory
    mkdir manual
    cd manual
6) Using wget, download all of the manual using the URL from step 4. Expect several hundred files to be downloaded, but it shouldn't take a lot of space. At my house this takes about 5 minutes and downloads about 900 files. Total size is about 50-60MB.
    wget --no-parent -r https://boats.yamaha-owners-manuals.com/om/LIT-18626-07-19/
You now have a copy of the manual locally. If you check the manual/boats.yamaha-owners-manuals.com/om/LIT-XXXXX-XX-XX/files/mobile/ directory you'll see a bunch of numbered jpg files. Each file is a single page of the manual. That's cool but we want a PDF! Here is how on MacOS I convert all the images (pages) to a single PDF file.
Code:
1) Open up the Preview application
2) When prompted to open a new file navigate to the folder that contains all the images.
3) Open ALL the XXX.JPG files at the same time. (You can use Command-A to select all)
4) From the Preview app File manu, choose Print...
5) Do not print these. Instead select the PDF dropdown in the lower left corner of the dialog box and choose to Save as PDF...
6) Name the file and you are done. You've now converted all the images to a PDF.
7) You can delete the manual directory you created in step 5 above.
I'm sure there are similar ways to do this on Windows and Linux, and even different ways to do this on MacOS. For me this is how I downloaded my 2007 212X manual as a PDF.
Extra Credit. To download *only* the JPG files that are part of the manual, append /files/mobile/ to the URL in step 4 above and you'll get just the jpg files with this command
Code:
wget -r --no-parent -A '*.jpg' https://boats.yamaha-owners-manuals.com/om/LIT-18626-07-19/files/mobile/
Since I used your request as an example for this write up, attaching a PDF of the 2007 AR210 manual. ? It's too large for the forum so here is a link that works for now. iCloud
Thx. It seems you are way more savy on computers then me. I know where the command line is using terminal but nothing happens when I enter promps. Assuming cause I do not have wgets on my system. Look like I would have to download from Homebrew and go thru all that. Whatever happened to paper? Lol. Dealer wants $65cdn for it and $172 for service manual.
Yes, on MacOS download through hombrew if you want wget. Enjoy the manual!
Thought I had it. See attached pic. Got al the way to end but when I save as PDF it only saves the 4 pages showing all 134 images. It doesn’t actually save all at once. Am I suppose to click on each image and save individually then put together? Thx again for the help!
Hey @Clipper, I already created a PDF for you at 2007 AR210 Owner Manual. This was linked above but may not have been clear :)
From your screenshots, you have to save every file you see to your local computer. That’s what the wget command in my instructions is doing for you. Much quicker than saving them all manually. :)
Once you have all the XX.jpg files saved locally, that’s when you open the XX.jpg files up in Preview app. It looks like you’re opening a HTML file or something in the screenshots.
Awesome. Thx Scott. That obviously flew right over my head ??‍♂️. Was looking more at the code you sent me. That’s fantastic!! Thx again very much.
