Amp Location/pictures
Wetjet57
Looking for pictures and suggestions of where everyone has mounted there amps. I am going to be installing two Wet sounds HTX-4 Amps, 4 REVO 6 speakers and two rev 8 tour speakers on my Ar210. Planning on running 0 gauge power and ground to a distribution block under the helm and mounting both there somewhere. Also, has anyone put a bus bar in to better manage the grounds? I was going to install a bus near the battery, run the primary ground from the engine To that and then all grounds from the bus bar.
Check out my install on my 17' ar240, starts on page 2. I also used wet sounds.
https://jetboaters.net/posts/245830/
