- Rosebud, Mo
- 242X E-Series
Currently I have all of my amps in the factory locations plus an additional Syn-dx4. Everything is mounted to the walls and you have to pull the amps out to tune. I do not like the setup very much so something will be done about it. I am actually trading my polk 5000.5 amp for another polk 4000.4 amp.( I like these amps they do VERY good so no amp debate in this thread ). I am also purchasing another dedicated sub amp because I am putting in another M10IB5 sub. Probably going with a M600/1. Anyways I have 2 options, build an amp rack in the current location under the port cabin seat for the four amps and have them so I can access the adjustment knobs, or 2) Pull everything out and run everything behind the helm. I would have to pull all new speaker wire and very costly power and ground cable.
Thoughts, ideas, pictures?
