Master-Spud
- Plamondon, Alberta, Canada
- Nautique
- Other
So I am trying to put the finishing touches on my stereo upgrade and I can't decide which way to go on the amp. So hopefully someone can give me some good advice. I like to do things right the first time.
What I currently have:
6x Polk DB651's 60 watt RMS
1x Wet sounds Syn 6 (running in mono 200wx2, 600x1) ( can also run 200x2 and 300x2 if I decide to add another sub)
1x Wet sounds SF-10FA 300 watt RMS
So now the question is what do I use to power the interior speakers, I am thinking at some point of adding an additional 2 speakers inside the cabin(so 6 in the boat, 2 on swim platform) so I would like the amp to have the room to be able to expand there if I decide to.
The options:
1) Pick up 2x Wetsounds syn 4, this would give me 125w on each channel... Over kill for the Polk DB651's, but if I decided to switch to a better interior speaker I'd have the power I needed (unsure if I will like the polk's once powered)
2) 1x JL Audio M800/8v2, this would give me 75 watts per channel which would fit the Polk's fine, but might be under powered if I decide to switch up to a more premium speaker in the future.
3) Something I haven't thought of yet
I'll be also adding a pair of Rev 8's to the tower, but the towers and the sub will be powered off the syn 6 so that isn't really a issue.
Am I going to destroy the Polk's running that much power to them if I decide to go with the Syn 4?
The options:
