- Rosebud, Mo
- 242X E-Series
I would agree with MOST of his statements.
5. The last step is to have a 4L jug of non-tox ( environmentally friendly anti-freeze ) which you would pour down into the water system of the boat.....same entry point where you hook up the garden hose to. You may need to get a 2nd adaptor for a quick change of hose as you keep the engine running during the switch. Once the non-tox has run through the system you will see the pink liquid coming out of the jet nozzle in the stern. Once the 4L bottle is empty, run the boat for 30 more seconds then shut off immediately.
This is where I sprayed my fogging oil in. I first took off the air filter and did it that way but it was a PITA. My brother pointed out the hose you have in your pic and I used that for the other motor. It worked fine for me and it was a lot easier to just loosen the clamp and the hose instead of messing with the air filter.This there a reason you can't spray the fogging oil in the smaller inlet tube leading to the engine as shown on the picture?? Instead of taking the whole air box assy off? View attachment 14046 ... pic courtesy: @JetBoatPilot
Same, makes fogging an easy no brainer...This is where I sprayed my fogging oil in. I first took off the air filter and did it that way but it was a PITA. My brother pointed out the hose you have in your pic and I used that for the other motor. It worked fine for me and it was a lot easier to just loosen the clamp and the hose instead of messing with the air filter.
