Anti-pooling
Yan Masse
Trois-Rivieres, QC, Canada
HO Impulse
Hi all
I would like to see how you guys install the anti pooling poles.
Can anyone post a picture?
Thanks
YM
Jacob Klein
Macomb, MI
Hi all
Thanks
YM
Unfortunately I don't have a picture, but if you have the Scarab mooring cover this is how I use them. The mooring cover should have came with two poles, one will be placed in the bow and other center of the cockpit area. These poles will connect to the black plastic puck like caps. Each cap will have three straps that connect to cleats at the bow and rear of the boat, as well as each other down the center of the boat over the window. I believe the straps near the bow are white and the rest black.
Pole height can be adjusted as well as tension on the straps to the cleat to form a stable connections all around.
Chad
Cincinnati, OH
Here is how I have mine setup. I've trailered the boat for several hundred miles like this and had it outside for a couple months last season. Never had any issues with water pooling on the trailering cover. Note: my strap between the 2 poles had a twist in it in this pic, but I made sure that was corrected before I put the cover on.
Slugger55
Jasper, AL
@Chad where did you get the caps for the poles? I have been looking for a set up like yours, but no joy....
Chad
Cincinnati, OH
@Slugger55 that's what my trailering cover came with. I was happy too see that it had these and assumed that was standard with the Scarab covers.
Slugger55
Jasper, AL
Nope! The 195 cover only came with the poles. Nothing else...
