Floydy
- Scarab
- 165 ID
Decided I'd upgrade the sound system in my 165 HO. Spent most of the day installing a second battery with an ACR relay system, and upgrading the wiring to 4 AWG to support the power requirements of the amplifier. Tested everything. ACR worked, all boat power worked but boat would not start. Checked wiring again. No start. Checked wiring yet again. No start. Rewired back to original single battery system with no ACR. No start. Neighbor comes over who has experience with Seadoos and Rotax engines. Says either a relay is out or the starter solenoid is bad. Seems reasonable. Went inside for a while to contemplate where to buy BRP parts in Nashville. Browsed about on this forum and read a post about a faulty engine cut out switch. Cut out switch?? Hmmm, did I install the cut out switch clip? Nope.
