AR190/192 - fuse panel?
ArmyChief
North Port, FL
Looking to add a possible chart plotter/MFD & 12 cigar outlet at helm, an additional 12 cigar outlet in glovebox.
Does anyone know where the fuse panel is?
Will I need to install a CB @ battery, run some wire up to GLovebox/Helm and install a remote fuse box?
Thanks
justason
SWAG Forum Lead
The fuses are reset buttons to the left of each switch, there is no fuse box for the applications you are targeting.
I ran a heavy gauge wire from a 2nd battery to a terminal strip under my dash. That wire is fused inline as it leaves the battery. I then tap off the terminal block for a few accessories I installed, some of them I fused again at a lesser rating than the main. (power plug).
ArmyChief
North Port, FL
@Master-Spud , that's exactly what I bought off Amazon for my Glacier Bay and installed (I believe I had to buy 2, one 6 circuit and one 4 circuit). I split the circuits, keeping the 4 circuit for HOT all the time devices like bilge pumps.
I think I'm going to get a 60 amp marine circuit breaker to install off battery switch. Run a 4 gauge circuit up to glovebox and then mount the fuse panel. How easy is it to pull a circuit to the driving helm area?
