Maslin
- Oregon
Picked up our 2023 AR190 a few weeks ago, we've had it out every weekend since. Thinking about trying the wakeboard today and had a question about the bimini top.
Obviously stowing the top would work, but that's a pain and we appreciate the shade. The manual says to lock everything together with the posts in the first hole, then tension the top to the second hole. It also says to drop to the last hole if using the tower. The second hole pulls the top tight, tight tight, there is no way I'm getting to the third hole. Pulling the rods down would dip the rear of the cover to clear the rope, it has a bit of a ramp up at the rear. There's just no way that's happening, the cover isn't stretchy and the front rods don't seem to be adjustable in any way.
Is there something I'm missing? Run it in the second hole and hope it doesn't rub too bad? Pull hard and hope the ball ends don't bend?
![](https://boattest.com/sites/default/files/YamahaAR190_2019_Thumb_.jpg)
