AdamB
- AR192
When I was growing up, my parents always had either an outboard or I/O boat. I now have a family of my own and am looking to purchase a 19 foot bowrider. I am planning to use the boat to wakeboard, ski, tube and cruise with my wife and son. The largest skier I would be pulling would be around 250 lbs.
We attended a local boat show this winter and decided to pursue a Yamaha AR model based on interior layout, Yamaha reliability and the price point in the 19 foot class. My biggest concern in the idea of a jet boat and also understanding the options I need to consider valuable when purchasing a jet boat. I have done a ton of research on the differences in the AR 192 and the AR195 but having a hard time wrapping my head around how much these differences will matter without driving each boat. How big of a difference did the articulating keel make from 2015 to 2016? If I install an aftermarket Cobra on a 2015 AR192 will that get me similar performance to the articulating keel? Would it be worth buying the bottom plate and keel rudder and installing on a 2015 (Looks to be about $600 in parts)? How does the jet system do with the tow sports? obviously these thing get up and go, but how is that performance affected under load?
I have read almost every forum on the "heat soak" issue of the AR 192 but not sure that will affect me or not in northeastern Wisconsin, being the water temps will not be over 80F for the most part. Most of the people I see posting about the issue are in much warmer climates and see water temps above 85 degrees.
I am looking at a 2015 AR 192 with 75 hours. The guy said he has never had an issue with the heat soak issue. This boat includes a snap on cover, wakeboard, kneeboard, 2 person tube, ropes, bumpers, anchor and board rack. The guy has it listed for $30K.
I am also looking at a 2018 AR195 off the showroom floor. Out the door I would be around $37K.
I have only seen a couple used AR195s in the area and they are not much less than a brand new model.
I would value some insight from jet boaters who have used both these models.
