BrandonG
Hey All, I have a 2019 AR195 and ran a little shallower in sand than I should have. I thought when I got the boat unstuck I would be able to start the engine and blow out whatever sand remained. Much to my chagrin I could sense alot of resistance to the starter when I turned the key but the engine started, however the boat would not move. I got it towed back to the dock and when I dug into it I found the threads on the aluminum driveshaft coupler had been stripped out.
Since I do have the jet assembly apart I'm thinking its an opportune time to install a housing with a plastic wear ring as the OE ring I installed a couple years ago got grooved with sand. I have a Solas stainless impeller that appears to have been spared but I cannot definitively determine what housing I need to order. I emailed SBT but they did not reply.
Would any of you in the know be able to provide a part number for the 2019 jet housing for the SVHO, Im guessing it may be the same as the Waverunner but dont want to risk it.
TIA!
TIA!
