chileanJK
- AR192
Last season I got a rope sucked on the pump and the rope was so hard that it broke the hull, I was far from the coast and when I cut the rope to take it out, the boat started to fill with water, started the engine and finally I got to house, slow but steady, took the boat to repair, once repaired, the pump is not getting the same power as before I assume the wear ring and the impeller are shot, what are you using? yamaha or aftermarket?
