yjander
- Marietta, Georgia
- AR192
I thought I would make a new thread for the work I did on my boat, instead of piggy backing on someone else thread, who was looking for a flush mount solution.
This is a garalick table system from amazon. Installed on the swim platform of my AR192.
I used 3/8 inch aluminum as a backer (it was all I had on hand). Getting into the area is easy. I am a little concerned about the amount of flex on the fiberglass in this area, so I wouldn't completely recommend it. I may get a 3/4 inch piece of plywood and glass it into the rear of this area to make it stronger, but we'll see how it does this season.
I used stainless steel mounting hardware and lock washers instead of nylalock...we'll see if that holds.
I might need to get a spacer to go behind the mount. I'm going to see how even the table sits on the water this weekend, hopefully if GA weather works
Amazon.com : Garelick/Eez-In 75359:01 Complete Side Mount Side Mount Table Leg System - Anodized Aluminum : Boat Seating Accessories : Sports & Outdoors
www.amazon.com
