dshscarab
- South Florida
- AR195
After reading where a couple wanted a power tower option for their Yamaha Jetboat, I decided to work on the idea.
- I measured the slack in the factory cable for when the tower was in the lower (folded) position. This gave a result of approximately 8". I then looked on Amazon to find linear actuators that have a stroke of 8". The Windy Nation kit complete with momentary switch appeared it would be satisfactory. I then ordered separate heavy duty actuator brackets which allow four (4) screws to be installed. I really wanted to use through bolts but I was not able to get to the underside within the compartment. Stainless steel screws such as the ones that come with trim tabs were used to screw the brackets to the side compartment floor. I then placed the tower in the full upright position. Actuator is lowest position (closed). I used chain that I purchased from Home Depot to connect the top of the actuator to the bottom of the adjustable bolt of the cable from the wake tower. Cable to cable could have been used. I thought using the chain would be easier. The momentary switch was placed initially in the battery compartment but I have since moved it after making the video to near the throttle lever so that I can control it while driving if need be. Positive from the switch was ran to positive battery switch post protected with a 10 Amp fuse. Obviously, ground to battery ground.
I have had this set up a few weeks on the boat without any problems or concerns. While under way, I do tighten the wake tower bolts so that no extra stress it put on the actuator brackets or the hull. (Since there is no through hull bolt / nut). I have included the links below.
Brackets: Mounting Brackets Link 2pcs US Stock for DC12V/24V Linear Actuator Motor Black | eBay
Actuators: Amazon.com: WindyNation (2pcs) 12 Volt, 225 lbs Linear Actuators + Up Down DPDT Switch + Mounting Brackets + Connectors (Momentary or Maintained Up Down Switch) (8" Linear Actuator, Momentary Switch): Home Improvement
Video:
Video:
