AR240 table won't fit on mount????
All Seas
Austin, TX
Hey guys,
Picked up a used 2012 AR240 and it came with 3 table mounts. 2 smaller diameter ones with different angles and a single lager diameter one.
The 2 smaller ones will fit in either mounting location but the larger one will not fit in any. BUT the table that came with the boat has a larger mounting hole for the larger diameter one! Needless to say, I cannot have a table setup as is.
Any one have any reason why this is? Maybe they lost the stock one and bout a replacement for a newer AR240? Any chance of an adapter collar or bushing or what the correct table I need then?
Coheeba
32408 Panama CIty Beach FL
Pictures would help. Could you use PVC pipe as a adapter to allow the smaller to fit on the larger?
