AR250 Aquatic AV Amplifier PNP Harnesses
Brandonloos_21
Myself and Jon Cain have been getting a lot of questions about upgrading audio on the AR250 with the Aquatic AV silver amp setup, so we developed a plug and play harness kit specifically for these boats.
The kit includes both sides, the input side connects to your new amplifier with RCA outputs and remote wire, and the output side plugs directly into your factory speaker wiring in your factory harness. No cutting, no splicing, no guessing. All wiring is marine rated tinned OFC. Factory zones are retained in both applications.
This harness supports two applications:
Replacing the factory amplifier entirely, the harness provides both signal and speaker wire directly to your new amp.
Adding to your factory system, retain your stock amplifier and tap signal out to a second amp for tower speakers, a subwoofer, or both.
We charge $100 for the full kit.
We also put together complete plug and play amp setups, amplifier prewired, pre-tuned, and spec’d for your specific application. Tuning is the part most installs get wrong. We handle it before it ever ships so your installation is straightforward.
Message myself or Jon if you want to order a harness or talk through a full build!IMG_0726.jpeg
