AR250 Radio upgrade
cpritchard
I am looking to upgrade my Radio but the problem I have run into is the unit is run through the connext system. Do they make a harness for plug and play to keep all the factory controls and just add an amp and tower speakers. Do I need to cut the factory wires and rewire if so has anyone seen a diagram on what each wire is.
anjboyer
Micheal011
Essentially you’ll need a lc2i or something similar, you’ll have to keep the factory amplifier to make it all work, if adding amps.
Just redid my 24 250 a couple weeks ago personally.
anjboyer
Not True!
I removed my "paperweight" of an amp entirely. You just pick up the speaker wires from Connext to feed LOC. Then new RCA's to new amps. Existing speaker wires out.. Easy.. You can still maintain Connext zone control as well if you determine what color speaker wires are running to each zone.
