HangOutdoors
- Royal Oak, MI
I have been doing some reading regarding backing plates for boats and different applications, light load vs heavy load and structural, etc.
Looking for some thoughts on the better/best material and thickness to use for a bow gunwale trolling motor mount backing plate. Also the type of adhesive to use. The following are what I was coming up with.
Of course the plate will be as large as I can fit to spread the load. It appears I have some local suppliers who have the different types of material available so will be going out to purchase today.
- HDPE / Starboard - It appears that this is not structural and not recommended, plus I read that it doesn't bond well with Adhesives as others do.
- 1/4" aluminum plate - Use 5200 or similar to help bond it.
- Marine Plywood - Easily shaped, but need to epoxy it fully in holes, edges etc.
- G10 - Seems to be the best, and can use 5200, or preferably glass it in with fast cure Epoxy.
