- Rosebud, Mo
- 242X E-Series
That time of the year to start thinking about what I am going to do to the boat this year since my Rhino project is almost finished so I want to make my fill times MUCH faster.
Ballast revision 1 was a single inlet port connected to 3 bags that had manual ball valves that I had to turn and I had a over the side pump that I had to use to fill a seat bag and a swim deck bag. Took about 30-40 minutes. Empty time was longer because I had to wait for the seat bag to empty before I could drain the under seat bag due to one of the ball valves being placed there. Bags were placed 800 ski locker, 400 beside each motor and a 750 on top of the seat and another bag on t he swim deck.
Ballast revision 2 was a Bluetooth touch screen on my phone using the same single pump but every bag had an electronic ball valve. Same fill times but I greatly reduced the empty times and I could empty while underway as soon as the seat bag and swim deck bag was emptied. Bag placement ended up being 800 ski locker, 2 400 bags under the port seat, 750 on top of the port seat and a 550 bag on the starboard side of the swim deck. I had to put the swim deck bag over there to get my jet back into the water. I took the starboard side out and put it under the port seat. I now realize this was a mistake.
Revision 3 plan is to add 2 more pumps with 1" line. My initial setup has 3/4" line. Running my current 3/4" line pump to the 400 bag put back on the starboard side beside the motor getting rid of the need for the swim deck bag. I am also going to use one of my ball valves and have a port up top so I can plug in a line and also use this pump to fill my seat bag with a larger pump. Should greatly increase this fill time. I also plan on buying another 800 bag and putting this single bag under my port seat. 800 in the ski locker will stay where it is at and the 750 bag on top of the port seat will be the only bag that is visible. I am going to ditch my Bluetooth setup and just go back to toggle switches, more simple and the wife would be able to operate it. So with 3 Johnson ballast pumps I would hope to be around a 10 minute fill and empty time. Those pumps say they are 720 GPH but I know they fill faster then that. Math says I should be around 6 minutes if they fill around 17 GPM which is what I clocked it at one time.
Ok so see any holes in the system or anything that you would do different?
