Welcome to Jetboaters.net!
When putting my system together, Wakemakers stated that I could drain through the vent, or through the pickup. It sounds like you are adding another penetration for the drain as opposed to using the vent. Is that correct? If so, what is the advantage of not using the vent fitting to drain?
A lot more check valves and a lot more hose. I already have 3 vents and one drain installed on the side of the boat. So adding 2 more holes in the side isn't a big deal. For the drain I would have to have a check valve on the pump and, check valve on the vent line and a check valve after the drain. This way I just need a check valve behind the pump and a check valve for the separate vent. I guess it is only 3 more but a lot more clutter.
*edit* Got to thinking about this and confirmed on my one line I have plumbed, still need 3 check valves.
The advantage for me is draining with a 1" line and using a smaller 3/4" for my vent since I already have that bought.
In your case @Addicted teeing into your vent line would be ideal.
A great place for vents is behind the cushions on the swim platform where they are high enough to never siphon but completely hidden. Too bad we cant use the pirahna pumps on a Yamaha but the fill ones must be mounted below water line and there is nowhere practical to fit them. On my system I drain through the fill so that there are no check valves in the fill circuit. They slow down the flow rate a fair bit. Cam.
@dustinjean Each bag is vented as well. Do you mean kill in a good way or a bad way? I love these pumps! I like that I only have to have one pump to do both and a pump per bag makes it killer! The biggest increase in fill time I am going to see is upgrading from 3/4" line to 1" line.
I have only been on one boat with the reversible pumps and I wasn't very impressed with fill times or how expensive they are plus i like mine being separated and emptying topside so i can see it draining or just listen and know when it is done, plus if a pump burns up its only $45 to replace each one. Mine has separate drain and vents as I seen someone mention the t fitting with check valves which will work but either way it all adds up quickly with fittings and hoses etc. I am about to work on my boat later today, ill take a few pics of how my pumps are plumbed into the intake side if i remember.
Mine will drain top side as well and the only thing that burns up on these are impellers. 20 bucks to fix that. Like someone has stated we don't have access to the hull to be below the water line to meet my comfort. I will be pleased with this system.
I just looked up the specs. It's 16' long, electric powered with a top speed of 6mph, holds 300 gallons of hot tub water (that's 2400lbs of ballast) and the water is heated by a diesel heater up to 140 degrees.
Ridiculous!!! But - I can see cruising the marina waterfronts in this bad boy.
Tested my system today. I can fill my locker bag and my port bag going 30 mph. Internal fill time was 4 minutes for 2300 lbs. The seat bag took 7 minutes with a 3/4 line. I an going to upgrade that to a one inch line. Super excited!!
