gbrits
- 242 Limited S E-Series
First time jet boat owner. Just got a 2015 Yamaha 242 Limited S and I need some advice on batteries and audio.
First of all, I've read on every forum that you should have a starter battery and a house battery. When I checked mine, I have two starter batteries (Interstate Marine Cranking 24M-XHD). My first question is, should I swap out the second starter battery for a deep cycle battery to be used as the house battery? If so, what type and does it also need to be a flooded battery like the starter battery?
My second question will probably affect the first. I'm looking to upgrade my audio system on the boat. Currently I have the original audio system (6 x JL Audio 65W speakers with the 4 tweeters in the tower, no amp, no sub woofer). I would like to upgrade to 6 x 100W RMS speakers, replace the 4 tweeters with 2 tower speakers (150W RMS), add a sub (600W RMS) and three amps for max power usage of 1,950W RMS.
So question 2a: Assuming I need to replace the second starter battery with a house battery, what size battery would be best? We don't dock for hours blasting music, maybe 1 hour max with the engines off. We mainly use the audio while cruising, but given that jet boats tend to be loud, the 65W speakers with no amp just isn't cutting it.
Question 2b: Is 1,950W RMS overkill for an audio system? I do not know what the difference in sound is between 65W with no amp and 65W with amp so should I go for the 100W upgrade with amp or just keep the JL Speakers and add an amp and sub? I realize this is a matter of preference but I would like to stick with just two batteries instead of having to add a third just for the audio system.
Thanks for any advice
