Ltwirth
- Wisconsin
- X
Curious if anyone has had any Issues with their battery chargers that have been mounted in the engine compartment? Not sure if it gets too hot in there causing the charger to fail. I have a 2020 212x and the stereo amp is already mounted in the ideal location in the rear port storage compartment so considering mounting in the engine compartment. There is a space on the top port side wall behind the engine hatch strut. I understand the ballast tank is on the other side of the wall but I believe it is on the lower half. Any other suggested mounting techniques on these newer models?
