Battery installation issue
danielcasey01
Port Republic, NJ
Hi Everyone-
I tried to install my battery and the lights on dash come on but engines will not turn over so something is not connected? Can someone help me with this?
Thanks in advance,
Dan
There are several wires that go on each battery post... And the connections need to be very tight. Poke your head in there for any cables that you missed connecting, and retighten both negative and positive posts.
New also does not always mean perfect. If the above fails you may need to check the current voltage of the new battery and confirm the battery is fully charged.
