Jimmyjudd66
Hello electrical gurus. 23’ ar195
I recently added a new 250amp negative bus bar by my single battery. The intent was to move every ground but starter from battery. In the battery compartment there already was a full factory bus bar in place. So what I tried to do was add cable that originally was connected from battery to factory bus to my new bus. And then connect my new bus to battery. (I.e. Battery> new bus> factory bus)
When I do that my fuel gauge shoots to 100% and my factory transducer and cruise control quit working.( I get the Transducer comm error and alarm on the dash)
If I reconnect the factory bus to the battery negative all works as it should. (I.e. battery > bus 1; battery > bus 2).
Can I not go bus to bus for ground wires? Currently the only thing connected to new bus bar is the factory house harness that controls the connect screen, dash switches, and stereo. All of those function as expected regardless of above.
