Compatico
- Other
- Other
That's correct Ohm's Law numbers in theory, but the stator current is an unknown value and it's not as simple with AC voltages that are rectified to DC, plus circuit losses. Obviously a larger stator coil with the same voltage output can produce more current, but using basic Ohm's Law calculation I=V/R doesn't directly apply here I think. Even if it was 1/4 of that though, 10+A is enough current to charge a lead-acid battery.Not sure this is the right math, but for the MR-1 (1.0) below, the math would be A = 13/.29 = 44amp on the low side, unless i'm missing something.
What we need is a volunteer with some electrical toys - someone with a high current ammeter who can put it in their boat and give us a realistic value...
