Battery Questuon
CQQL
IMG_9148.JPG IMG_9155.JPG i have a battery question here is a picture of the battery that I have in my 2016 AR192
One of my friends gave me smart battery charger. I can't figure out what settings that I use is it wet, gel or agm. Also temp and charge rate do I use?
Thank you
ruztew
CQQL
what about charge rate do i use 2A, 10A or 30A
JDinfla
2 amp is a trickle charge to keep it charged. 30 amp would be to jump start if batt was totally drained and you wanted to start boat. I have heard from friends with motor homes if you leave it on trickle charge all the time you battery won't last as long.
Maybe a battery expert will post more info !
