blacksapphirez
- Charleston, SC
- SX195
Every one knows the factory battery location is not the best for storage. It blocks a lot of space in the compartment which renders it useless. So I relocated them towards the back of the boat where it is really not useful for anything other than... Battery storage. I do not have a on board charger so I need to remove every once in a while to bring them home to charge, so I have decided on a sliding tray type.
you do have to undo the wiring harness that is secured on the flooring. remove screw and cut zip tie so you can maneuver the harness easier. I did not have to move my battery switch or extend any wires for this mod.
Items used
Two plastic cutting boards-https://www.walmart.com/ip/Mainstays-15X20-Cutting-Board/13397990
Set of Sliders 18" - http://www.homedepot.com/p/Liberty-18-in-Full-Extension-Ball-Bearing-Side-Mount-Drawer-Slide-1-Pair-D80618C-ZP-W/202200644
One Door stop -http://www.homedepot.com/p/Everbilt-Oil-Rubbed-Bronze-Wall-Door-Stop-15705/202034115
The cutting board does not fit. I had to trim about 2 inches off the side. Not pretty Don't care
Mount the sliders on the board
Mount the battery tray on the board. I intended to make it sit like so....
But guess what, does not work. the fuel expansion tank? is in the way. Holy Shit... by the time i figured it out I was ALL FINISHED! I had to undo everything, relocated the battery tray to clear this tank.
For sure I do not want the batteries to fly forward. Drilled two holes and dropped pair of engine valve to secure it in place
When the tray is extended, the weight of the batteries on the board will make it sag and wear out the sliders. so I put a door stop several inches forward of the board so it can sit on it while the slider is in extended position
now you have a HUGE compartment that you can use!
also decided to move my fire extinguisher
Items used
