Wrecked Rooster
- Ada, Oklahoma
@Wrecked Rooster IMHO, FWIW, I would personally change that setup. Our engines do not draw like a typical outboard or inboard. They gave me the same spiel, and I talked to them multiple times, as well and I ran it by some Marine Electrical Guys, whom are quite familiar with our Yamaha boats and they preferred the breakers as close to the battery as possible so it would take the batteries out of the loop in case of high draw. When they do have multiple breakers for whatever reason in other boats where they draw more on engine start they will increase the breaker size but still have each battery with its own breaker as close to the battery as they can get them. We can start our boats with mini motorcycle batteries. If starting them is popping 100 amp breakers you probably shouldn't be running the boat at all till that is figured out.
If you short a wire you want them breakers to pop and take the batterie(s) offline. There is most certainly a good reason to add them to prevent fire or system damage, so I cannot agree with them on that either. It appears that the way you have it set up as well as the picture, if there is a short or other electrical problem there is nothing stopping a draw from the batteries till either components fry or wires catch on fire as long as that switch is on. It may never come to that, but a fire while you are off shore or wires melting and you cant run the boat, is a pretty bad spot to be in.
At the very least, keep it the way you have and put two more breakers in between the battery and the switch for safety. You could move the 100 amp ones down to the Batter to Switch cables and buy a couple of smaller ones for the ACR.
One more thing is that our stators don't put out as much as other types of engines alternators, etc. So having fuses inline with the ACR is somewhat pointless since charging will never come close to anything but minimal amps.
Of course you should do what you feel comfortable in doing.
I appreciate the reply. I’m totally out of my element when it comes to this stuff and won’t even pretend I know what I’m fully doing. I actually have some 60A breakers (same style as the pic) on hand if that would be better. I know you have your breakers between the battery and the switch and the ACR going to the same post as the batteries on the switch.
I still have the 3 factory fuses installed (bilge, stereo and everything else). I guess my question is, the factory setup doesn’t have a fuse for the motors. Wouldn’t adding a breaker/fuse from the battery to the switch do just that?
