1BadTundra
- 212X
Ok, I have a 2016 212x. It has one battery switch, and a DVSR. The battery switch has a 1, 2, and a 1&2. I understand what the concept here is, but where should I run this switch? If I set it to 1, will that be my starting battery? What if I set it to 2, or set it to 1&2? I put my voltmeter across the gauge power and worked the switch. The voltage didn't change. If it did, it was by a 1/10th of a volt, which a DMM fluctuates that much anyway. When I turn the switch to the off position, it does kill the power.. So what gives? What should it be? Where should I run it? I have an amp, and accessories set to one battery, but now I'm worried I wired all that to the starting battery.
