dzeppos
- Coto de caza, CA
- Limited S
I have 2016 242- Shorelander Trailer. I've posted recently about the bent axle and new tires. Both solved, but every since they redid my brakes last month, i've lost three bearing buddies on the same left rear axle (which also has the brake)
I was half to Lake Mead 120 miles out - when I notice my bearing buddy was off. See attached.
Even though the last two times, each shop sent out a guy to reattach (They literally came off within a few miles).
So here I am, in Barstow - middle of nowhere, I find an RV show, and I happen to have extra bearing buddies 1.98 M198, and I make sure one of their guys hammers it in with a mallet, and puts gasket/epoxy (even though we did that each time). Further, I know it sounds crazy, I put duck table all round. Well - it worked. Got to Lake Mead and am going to take it to another trailer center to see what they can do.
My trailer guy back in California thinks the guy who did the breaks didn't resurface the rotors correctly. The store that did the brake rotors said the hub went bad. I don't think it would after 4 years and with faithful annual service on the trailer.
Two questions:
1. The wheel wells are hot. Not enough to melt something but both wheels on that axle (with the brakes) are hot after driving a good distance. I know they will be hotter than the other wheels on the non-break axle.
2. Anyone have any idea what it could causing the 3 bearing buddies to come out know over the past 4 trips (same wheel)? I'm going to Lake Powell - another 280 miles from Vegas -and can't afford to get stuck
Really appreciate any advice and/or suggestions
Thank you in advance
Demo Zeppos
Two questions:
Demo Zeppos
