Blazin14
- Elkton MD 21921
I have a AR230 2007, and wondering about adding grease to the bearing housing, but the manual is not that clear.
I have some questions?
1) How can you tell if it needs grease added? squeeze the tubing?
2) Can you use marine wheel bearing grease?
3) I have grease slippage, it that normal, why does that happen? (see pictures)
4) Is the grease for the main prop cone (housing), if so it seems very important and Yamaha should provide a more exact method? (yes /no)
