Best boat cleaner?
Jenny285
Carolina Skiff
What do you guys use for your fiberglass boats to get them really clean? I've used a few products and was looking at some of the cleaners listed here 4 Best Boat Cleaners Reviews for 2019- Get Your Boat in Top Shape with. I just do not know which one to use. I would love some feedback for tried and true products that don't cost an arm and a leg. Thanks!
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
My dad and I tested out 4 different hull cleaners side by side. Of the ones we tried, the Spray Nine was by far the best and generally worked really well. Sorry for the Canadian link:
Spray Nine Marine Boat Bottom Cleaner, 946-mL | Canadian Tire
Doesn't require much elbow grease as compared to others. I usually lightly mist the hull, then apply the cleaner, brush it on (usually doesn't require too much effort here), let it sit a few minutes, then rinse off. Done.
Jenny285
Carolina Skiff
That looks like it would be perfect! I am guessing it could be shipped to the US?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
I have no idea if Canadian Tire ships to the USA, but I'm certain you can get this somewhere in the USA. Amazon seems to carry their products: Spray Nine
I would avoid importing to the USA... cost you an arm and a leg.
Jenny285
Carolina Skiff
Thank you so much!!
jEt_jAk
SoCal
AR195
Hot Sauce/Boat Bling is the best I have used.
Jenny285
Carolina Skiff
Thanks for the info! I will check it out!
zipper
Boston Whaler
We have been using the Starbrite line of products for years now. Many of their products can be found at local hardware stores. I can say that Instant Hull Cleaner works very well to remove the growth, including zebra mussels, from a season of wet slipping. Their non-skid cleaner works on deck. Spider Away works, as well as the Spider and Bird Stain remover. I have had bad luck with their small spray on gel bottles leaking during use. But with two boats to clean we buy in bulk and apply with an extendable car brush, from a bucket. Many here use Boat Bling Hot Sauce to keep their hulls free of hard water spots after use.
Jilly Ruby Jane
Bayliner
SX192
3M Marine, It is a good detergent and is recommended by many, there are many other substances you can find more information in here.
dan144k
Palatine, IL
I started using S100 Total Cycle Cleaner to clean the boat.
With a brush and water rinse it is removing all dark and yellow spots and making hull bottom and fiberglass white again.
Babin Farms
Lower Alabama
We wetslip so our hull gets discolored fast, we try to pull the boat out every once in a while to go to another body of water & also clean the boat up while it's out. Just like everything, if you keep ahead of it, it makes things much easier than just letting it go. Starbrite gel hull cleaner works great at getting the lime scale and whatever else is at or below the water line of the hull. We also use a spray wax on the upper portions of the hull anytime we pull the boat out of the water
Beachbummer
Houston TX
If you are ready to lose your wax, Barkeepers best friend soft , is very inexpensive at the supermarket and does wonders for grime lines on the hull. I was super impressed with how well it preforms.
Jane305
Grady White
You can use Star Brite products for fiberglass such as Ez-On Ez-Off, Fiberglass Stain Remover. I'm using Starbrite EZ-ON EZ-OFF I simply put some in a spray bottle, sprayed on the hull/bottom, lightly brushed with a soft-bristle plastic brush, waited about 5-10 mins and rinsed off. Absolutely amazing product.
