Best site to buy a cover 05 AR210
Yamanator
CNY
Tige
Put a deposit down on an 05 AR210 but needs a new cover. What cover's are best or work best with the tower?
Any other words of wisdom on this boat feel free to share. First jet boat. I was looking at newer but came across this deal near me that I couldn't refuse. Also how much of a pain is it to take the tower down for storage?
Outer Armour is among the best - custom fit for your boat if they can still make one for the 2005 model year. It doesn't use straps and is suitable for trailering. Second would be the original Yamaha cover if you can locate one - but only suitable for covering/mooring not for trailering as it will rub on the gel coat. Third would probably be a custom cut cover from a local marine supply company that will measure and fit a cover to your boat, but again not suitable for trailering.
When you trailer the boat, remember the cushions inside the boat need to be held in place or you may loose one from the buffeting winds. Through town at 30 MPH is not an issue, but highway speeds may suck them out.
If you've never driven a jet boat, they're a blast to drive kinda like a big jetski, but much more comfortable. They handle differently but effectively once you learn how. Google is your friend for this info. Note they're reasonable for cruising and towing, but are not designed for maximum high speed performance as the jets tend to "plateau" at the upper revs as they struggle to suck in water fast enough to produce more thrust to overcome the hydrodynamic drag of the larger wetted boat surface. Jetskis can zip along because they have very little drag, but a 21' boat has a lot more surface drag. If top speed is your goal, a prop boat is your answer. But if tubing, skiing, wakeboarding, and cruising is what you want, a jetboat does it very well.
Lowering the tower is very easy with 2 people - just loosen the retention handles and the second person can easily hold and lower it, it's aluminum so it's not too heavy. Do not trailer with the tower lowered, as the support cables are not intended to handle the vibration and shock of movement during transport on a road/highway. Keep the tower raised unless storing it.
Thanks! Wakeboarding, floating around listening to tunes and general cruising is what we are in to. I've had go fast boats in the past, more about the chilling these days.
I won't be trailering the boat, it will be on the lift all summer so more concerned about keeping water to a minimum.
Can't find an Outer Armour cover that fits this boat.
Did you try contacting them directly? I'm sure they still have the design specs and could make one for you:
Yamaha claims that their new covers are trailerable and strapless. I need one for my 212 Limited S, but I do trailer on Interstate highways. Does anyone here have any experience trailering with the new Yamaha cover? Will it scratch the gel coat?
While shopping around I noticed there were no straps on the 2018/19 models they had in stock, just a ratchet strap at the rear similar to the Outer Armor style. I didn't notice any vacu-hold points but perhaps these newer ones are ok for trailering too. I'll poke the dealer about it next time I'm down there looking for info.
My 14 212x came with a Yamaha “ Ratchet cover”.. like the new style. Unfortunalty 5 years in the AZ Sun has killed it. You can see “ Buff/wear marks in certain areas of the gel coat from either the previous owner towing with it or it just sitting in the elements.
Has anyone here towed with the new Yamaha covers?
