twentiesforever
- Burlington, VT
- SX
Hey Forum,
A few questions about my bilge pump and how it works. Sorry for being a noob at this. When Im out, I always have the bilge switch on in case water comes in so its all automatic. I left it on and went home for a couple of days. I came back and it had drained my battery. I recharge my battery and go out and all is well. Today while messing around, I noticed that the light on the bilge switch is not on. It was terribly windy today and was alone so I couldnt tell if the pump turned on or not when the switch was activated. I also noticed that the breaker was in the out position. Its a little hard to tell since its covered in rubber but it felt "out" if i tried to rub my finger across the breaker rubber nipple instead of just in. I tried pushing it back in and it wouldnt stay. So questions:
1.) If everything works fine, does the bilge pump turn on by itself if there is enough water in the bilge?
2.) In my situation, is my pump off and broken?
3.) Is my breaker broken? I thought breakers normally do not fail so is there something else awry?
4.) Do I need to replace my pump and if so, is a normal swap all that is needed?
I will return with a buddy to see if the pump really is broken or not but I was confused about its wiring and the breaker it has. Im used to the old fashioned fuses.
