Bilge pump fuse
BobbyP
Glastron
GT
any one know which one it is?
It might be a breaker because it’s directly connected to the battery if you turn your battery switch to off the bilge pump will still run
It ended up being the pump. Not too difficult to replace. The dealer had the pump with the connector for $110. So, of course I bought the exact same sub650 off amazon for much less. It did not come with connector, but I just spliced and heat shrunk the wires in and it’s as good as new.
One thing I did learn, the pump bracket is glued down not screwed in....lol that took a minute. However, when changing the pump, just twist and pull the old one out of the bracket and put the new one in....no need to take off bracket. Same thing with filter screen.
https://www.amazon.com/SUPERSUB-Sub..._SX236_SY340_QL65&keywords=sub+650+bilge+pump
