I_squared_r
- Colombia/South FL
- 242 Limited S E-Series
I bought an AR192 that I will be trailering. I'm debating whether I should install an extra automatic bilge pump with float switch. What has everyone else decided? I tend to worry a lot so i'm leaning towards installing a Rule 27SA (1100GPH) in the back by the exhaust muffler. I also want to seal the cover better because I noticed that they didn't put much sealant there. Did you drill a hole and install a bilge outlet?
