Bilge pump
Terrance
Porters Lake Nova Scotia Canada
Glastron
GT
Anyone know how to get this bilge pump to stop pumping? It automatically sucked up rain water till the bilge was empty and never turned off.C435CC4C-DABE-4D10-9FB3-0D1CABB22CCF.png
tdonoughue
The Woodlands, TX 77381
Unplug it? Or pull the fuse to it?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Yes. Had the same problem. The water sensor is in the rectangular portion at the opposite end of the intake side. The trick is to ensure that it's at a steeper angle whereby the sensor is higher up. What I did was clamp a metal clamp around the part with the writing and had the thicker portion of the clamp underneath the pump. This angled it such that the sensor is higher up and the intake is lower. Now it actually stops.
Terrance
Glastron
GT
Hi Luc, Thanks for the advice. I will take a look at the angle of the pump and re-adjust. merci mon ami!
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Yeah, my logic was that I'd rather have a bit more water in there then kill the battery by having it run all the time. Plus, you can always simply turn on the bilge manually once you're there to empty the last bit. Also, this will bring the intake lower, thus allow you to pump more out (although manually at that point).
