Bimini Pin broken need replacement
jgourlie
Alberta Canada
AR192
I managed to break one of my pins today. This is the part number F2J-U316A-00-00 and I have found a few sources for $25. Shipping to Canada is another $25. Does anyone know something else that will fit or a cheap place to buy? @Crob83 2B3041AE-2324-42FC-8313-A55C46F8CD90.jpeg
djetok
Edmond, ok
You can get them at bass pro shop or a boat place. We keep extras in the glove box when the tether let go and became one with the bottom.
jgourlie
Alberta Canada
AR192
good to know...I will try and check out Bass Pro
would you happen to have a part number for them at bass pro?
djetok
Edmond, ok
sunbyrned
Louisville, KY
@jgourlie I wasn’t sure if you were kidding about the golf tee. I like that simple idea and might try it as well. I just want to make sure it’s not going to break on me at high speeds and hurt someone or the boat. Have you had good luck with them?
jgourlie
Alberta Canada
AR192
I just test fitted it this morning. I only use plastic golf tees so they should be better than wood. I have to pound the pole into the bracket with a hammer because my Bimini is so tight as is, I was thinking that I probably wouldn’t need a pin anyways. The tee should be great. I will let you know if it works
sunbyrned
Louisville, KY
I use a pin and it goes in without hammering. Just have to lift the pole to take the pressure off of it. Golf tees might be a little easier than a blunt pin.
