Pointblank
- Houston, TX
- Limited S
I am curious to see if anyone else with a black aluminum wake tower has experienced this level of corrosion. This is the factory-installed DiamondBack wake tower on a 2014 Yamaha 242 Limited S. To me, it seems excessive on a boat that's been used exclusively in freshwater and under cover its whole life.
From the little bit of research I've done, it appears the underlying cause is an interaction between dissimilar metals--stainless steel bimini brackets in this case and the aluminum tower. Is that correct?
Any recommendation on how to prevent further deterioration, aside from re- powdercoating or painting? Is it mostly cosmetic or cause for concern down the line?
